Aller au contenu principal
Sorti le 25 septembre 2015. Modèle A1688/A1633. La réparation de ce modèle est similaire à celle des versions précédentes et nécessite tournevis et outils pour faire levier. Disponible en GSM et CDMA / 16, 64 ou 128 Go / Argent, Or, Gris sidéral ou Or rosé.
31 questions Voir tout
Unable to activate Touch ID on this iPhone
Hi, I’ve just tried to replace my rear camera. When I put it all back together and turned it on, it says I’m unable to activate Touch ID on my iPhone. I’ve tried disconnecting and reconnecting the Touch ID at both connectors (one at the home button and the other by the digitiser connector). This hasn’t made a difference. The home button has never been replaced and the Touch ID was working up until now. Home button still functions. How would you go about fixing this problem?
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
Ajouter un commentaire
2 Réponses
Solution retenue
You'll want to take a close look at the Home Button Flex cable that connects the Home Button, goes underneath the backlight shield and comes back out at the top of the screen. If the flex has a light tear or if the connector is damaged, it will impede the TouchID from functioning properly.
Unfortunately, if that's the problem, the only way to fix it is to replace the screen assembly.
Indice 4
1 commentaire:
I've tried changing the flex cable from the home button, but it still doesn't work. What should I do?
par
You have damaged the flex cable for the Touch ID sensor or have damaged the connector on the board. Replace the connector and tell us whether it works or not.
Indice 0
2 commentaires:
Replacing the screen worked fine and the Touch ID works again. Thank you for helping!
par
No problem,mate,glad to have helped!
par
Ajouter une réponse
Alex sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 4
Total : 14,181
