My kindle will not recharge because the charger plug will not stay in.
connector on kindle seems to have been
loosened somehow
loosened somehow
1st. You must verify that the charger is working by testing the voltage at the plug.
2nd. Using the Search at the top of this page; How to replace charging port
I had a universal charger that included many, many different sizes of plugs. One fit perfectly into a worn-out tablet saving the expensive repair costs. (and a lot of patience !)
You might look into that option.
The problem is inside the 'jack'. There is a S shaped spring that locks the plug. It is worn nearly flat and no longer 'snaps'.
Hey there! just a tip, make sure to include the link(s) instead of just saying to search something.
thanks for helping out though!
Aiden - without thinking - I omitted the double quotes from the search text. I wanted him to see 90 broken charger ports, not 1000 un-related words!
Comment:
Todays SEARCH has lost its SQL full-text-query abilities, meaning...
it should be re-named to 'FIND-all-these-words' !
search for it yourself, see if you can find a resource that will help, and provide a link. there's a chance that searching that will not yield good results. bottom line, do the research yourself
also, not sure what you meant in your last comment.
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 94
