Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Écran de 7,9 pouces / Modèle A1454 / Disponible en noir ou blanc / Annoncé le 23 octobre 2012 / avec 16, 32 ou 64 Go de capacité
Replacing FPC connector, pins disappeared!
Hello
I was changing a digitizer that had been changed again and noticed that some pins were almost ripped off. After testing the new digitizer being happy that everything works smoothly (there were more repairs), when I removed the digitizer to reassemble completely 3 pins of the fpc connector followed the digitizer :/ .
After some searching for the appropriate flux and heat protection tape (Greece's market on this parts is extremely low, they had only plumbers flux) I started the repair.
I've been stuck at a point though.
Two pins on the logic board are like they disappeared after moving the soldering iron across the pins.
See links bellow.
Exhibit A
Exhibit B
What's my next move?
Thanks,
Dim
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Check these images.
They give an indication where the missing pads are connected.
Solder a new connector then make a jumper from the connector to a test point on the back of the board or a nearby component.
Indice 2
2 commentaires:
Thanks for the info!
The first picture confuses me a bit. Were do I connect what?? At any point of the highlighted ones I can connect the missing pin of the pad?
For the second picture I will use a thin wire to connect the pin of the pad to the back of the board?(or any other highlighted components)
Sorry if my questions are a bit off, I lack the appropriate experience for this kind of microelectronics repair but I don’t have another solution than to fix it my self.
Thanks!
par
The points in red <=> highlighted are all connected so you can use a thin wire to connect to any of them. We like to use the test points on the back of the board, but you can do whatever you like as long as it works.
par
Ajouter une réponse
MDims sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 21
Total : 1,086
