Try to Hard Reset your device by following these steps:
1. Remove the battery and wait for a while
2. Meanwhile, you can remove your SD card as well
3. Plug the battery again
4. Hold the “Volume up” and Power button simultaneously.
5. Select “Factory reset” option by using the Volume up and down keys
6. Validate your option with the power button
If the phone has gone into “hard-freeze”
This can often happen with Android. Simply remove the battery (if applicable) and long press the power button for another 30 seconds.
Reinstall firmware
If nothing else seems to function and you are not able to figure out how to fix a Huawei phone that won’t turn on, then consider reinstalling the firmware.
A voté
Annuler
Indice
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
