Back panel won't clip back on xps 13.
So I took off the back panel to upgrade the ssd, however the clips that clip onto the panel at the bottom part near the hinge of the laptop don't seem to be there anymore, so the panel is not clipping back on.. Is there anyway I can fix this? I'm unable to find the pieces that came off the laptop . TIA
2 commentaires
Hi @md0902 ,
Looking at the ifixit guide to replace the SSD in an XPS 13 9350 laptop it appears that the back cover is held in by screws.
Are you saying that the screws won't screw in to hold the back cover any more or do you have a different model XPS 13 perhaps?
Remplacement du SSD sur le Dell XPS 13 9350
par jayeff
Once, you take of the screws, you have to pry off the back panel. The clips that hold the panel to the body when you pry it off are not there when i try to clip it back on, so there is a gap at the back part where the hinge is located.
par Myro
