Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti en mai 2014, le Dell Inspiron 15-5547 est équipé d'un processeur Intel Core i7.
Boot from bios to external screen, broken laptop screen.
I have a clients lap top and I can't get the computer to boot to an external monitor. The drive runs there are no warning lights and the computer seems to be functioning. Client spilled water on it dried it out and called Dell they walked her through some things then the screen shut off the other day. Now I can't tell if it's the graphics hardware/software or the screen. You can see the screen back light turn on but no image. Trying to boot to an external monitor but not getting anything. Any tips?
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires
Try cleaning the plug and socket of the LVDS cable running from the motherboard and screen, using isopropyl alcohol.
par Partager
I've attempted the same thing as I've worked with Dell Chromebooks before and they allow external monitors to boot to. This Inspiron doesn't intend to boot from a monitor it seems.
par Partager
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@mbmd
sounds like a shortened motherboard. If you can not boot to an external monitor it is most likely that you have a short if the GPU circuitry hence the reason for not displaying an image. you’d have to get to the moterhboard and check for water damage (clean the board with some 90%+ isopropyl alcohol. Check for obviously damaged components. There is a slight possiblity to find a schematic but we would need the exact motherboard your computer has.
Indice 2
1 commentaire:
This was the problem had to get the board replaced.
par Partager
Ajouter une réponse
Megabyte Medic sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 13
Total : 584
