Delonghi 6900.m No steam. Weird noise
I have a Delonghi Primadonna Exclusive 6900.M
Everything seems to work fine except for the steam.
It will produce hot water out of the water spout and will also do a full descale.
But when I choose the steam function or put the milk canister on it makes a funny noise like it has a blockage because when I stop it some steam comes out the back of the machine. I have always done the descales and changed O- rings when needed. Greased up the enfuser when was getting stuck, that fixed that. Put rubber grommet in suction straw on the milk canister that has a smaller hole in it to slowdown the milk feed so that it heats up more, got this from delonghi. Hot cuppachino now.
What do you think is the problem. Could it be the solenoid doing this.
Update (06/23/2018)
The machine has a external push on water and steam spout.
This is the machine.
Also a milk jug.
1 commentaire
Hello,
have you solved the problem? Because I have the problem on the same machine (delonghi esam 6900)everything is working execpt steam…..
thanks
sory for english I’m french….
par Eric
