Aller au contenu principal
Système d'exploitation Windows XP
Questions au sujet de 3 Voir tout
How to take laptop back to factory settings
i have a Toshiba Equium L20 - 197 Laptop serial number X5036405W with Windows XP and want to takeout back to factory settings BUT can only find a restore point not a factory settings
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
Have tried the press the 0 keys this doesn't work
par
Ajouter un commentaire
3 Réponses
Solution retenue
Obviouly some one has completely re-formated the hard drive and wiped Toshiba’s Factory Restore partition.
Just download and use the Mircosoft Product Key on the underside of the laptop or use , on the existing OS, one of the programs that finds the product key on the hard drive. Probably best to do both or find a used XP CD with a product key.
Just curious. Why do you want to do this?
Indice 1
Here's how to do a factory restore:
  • Power down the device.
  • Unplug everything - mouse, keyboard, monitor, etc.
  • Make sure the AC adapter is plugged in.
  • Press and hold the zero key while powering on the computer. Keep holding it till you see the recovery warning screen.
  • Pick your OS.
  • Follow the remaining prompts.
The drive will be wiped clean when you do the factory restore. If you don't want to do that, do not proceed.
https://support.toshiba.com/support/view...
Indice 0
1 commentaire:
This doesn't work Ive tried this and it just continues to open up as normal. :-(
par
Shut down completely and then as soon as you power the device on start pressing the f11 button. Or press and hold the f11 button and it should open prompts to factory restore it.
Indice 0
Ajouter une réponse
gill.prior sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 50
7 derniers jours : 303
30 derniers jours : 1,404
Total : 10,859
