Aller au contenu principal
tahoe bogs down when accelerating
why does my 1999 tahoe bog down and sputter when i try to accelerate?
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
What engine does it have? Standard or Automatic?
par
Ajouter un commentaire
2 Réponses
Solution retenue
No knowing what engine size or what transmission you got, I would think that it starts with checking your airfilter and air intake. Make sure it is clean. After that change your fuel filter and check your fuel pump, and fuel pressure regulator. The service manual calls for a pressure of 58-62 psi anything below that would indicate that a new pump is needed. The other option is the vehicle speed sensor on your transmission could be faulty. Have your vehicle checked for any error codes at a place like Autozone (it's free) and see what they come up with. Right now it does sound like a fuel problem . Good Luck and let us know how it is going.
Indice 2
1 commentaire:
My tahoe was doing the same thing and Igor a new gas pump and fuel filter and problem solved.
par
Check for vacuum leak ,pcv valve clogged, or clogged catalytic converter.
Indice 0
Ajouter une réponse
internal46 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 49
Total : 9,031
