Aller au contenu principal
The Shark Rocket HV301 is the second installment of vacuums in the 300 series. It is a two-in-one vacuum that comes with several attachments, making it capable of cleaning on different surfaces. Its sleek and lightweight design make it easy to maneuver around any household.
Questions au sujet de 29 Voir tout
No suction - not a filter or clogged hose
My Shark is a Rocket True Pet purchased from Walmart in 2015. Great vacuum until today. I vacuumed our hardwood floor of pet hair (maybe 15-20 minutes) and it did well. Went to vacuum a small carpet with dog hair and nothing. Running but not picking up. I've detached the main unit from everything and removed all filters. It turns on and sounds fine but no suction coming from tip. I see nothing else I can clean.
Répondre à cette question J'ai le même problème
Indice 3
1 commentaire
MINE HAS A CRACKED HOSE IN THE CARPET FOOT ATTACHMENT AND i CANNOT FIND A NEW FOOT
par
Ajouter un commentaire
4 Réponses
Réponse la plus utile
Most people miss this one:
Cause 1
Exhaust Filter
The exhaust filter traps particles as the air travels through the vacuum cleaner. If the filter is clogged, the vacuum cleaner will not have proper suction. If your vacuum filter is clogged, refer to your owner’s manual for cleaning instructions.
Indice 3
1 commentaire:
Thanks but it's not a filter. With everything detached and removed the main unit turns on and sounds like it is working but has no suction.
par
If your Shark vacuum is no longer picking up dust and debris, see the Shark ION Robot R75 Is Not Collecting Debris problem page for possible causes and solutions.
Indice 1
Hi
I’m no Shark expert but I know my Dysons like the back of my hand and I find when you can’t find the problem it tends to be a blockage from with in the cyclone (the bit that’s usually above where the dust collects)
You can do 1 of 2 things here
The best option is to completely disassemble the cyclone and hand clean all the parts with hot soapy water
The second option is Easier but doesn’t always work: if you can get a deep bucket and fill it up high and submerge the cyclone in the water and shake it up and down so all the water get is in a clean it ,leave it I. A warm room for a week to dry out
Hopefully this helps
If it doesn’t let me know and we can try something else
Indice 1
You have a rip or hole in the lower hose.
Indice 0
Ajouter une réponse
varider424 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 20
30 derniers jours : 110
Total : 2,946
