Aller au contenu principal
Annoncé en août 2017, le Galaxy Note8 est le successeur du Galaxy Note7 qui avait dû être rappelé. Le Note8 a été mis en vente en septembre 2017.
My S Pen broke off, half still inside, how can it be removed?
Help get SPen out of phone?
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
2 commentaires
I used a lock picking tool it had a hook on It tried for 30 min then I prayed put it back in felt it move and out it came .
par
Grateful it worked
par
Ajouter un commentaire
4 Réponses
Solution retenue
Smack the bottom of your phone or lightly hit it on a table, it should come right out when you shake it!
Indice 10
6 commentaires:
This worked for me, thanks.
par
purrrrfect solution , thank you
par
Worked for me too thanks!!
par
This worked thanks alot. ?
par
Worked great for me. Thanks!
par
Afficher 1 commentaire en plus
Tweezers? Here is a video of someone getting one out:
https://www.youtube.com/watch?v=zA5xYT-x...
Indice 1
1 commentaire:
My S pen broke outside phone and i put it back in there Not thinking. The pen came out but part of the plastic encasing remained inside. How can I get this to come out?
par
Mine was stuck way inside the phone. I used a drill with a tiny drill bit and drilled into the hole in the stuck s pen. All you have to do is simply pull it out. It ruins the s pen, but you can get a replacement on Amazon
Indice 1
2 commentaires:
you can use a phillips screw driver and insert it inside. it worked best for me to take out the broken s pen inside.
par
Yay! the screwdriver is the only thing that worked for me! thank you so so much!
par
I used the old-type iron twist serving to prepare a hole in the wood plate for screwing-in the screw. I think this is the best solution!
Indice 1
Ajouter une réponse
Robin Kamps sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 13
30 derniers jours : 72
Total : 23,090
