Aller au contenu principal
Tutoriels et assistance pour réparer son sèche-linge.
20 questions Voir tout
My kenmore dryer 81122 has Rotating blinking lights.
i put the dryer recently on normal 1 hour cycle , no wrinkle guard and after a few minutes it shows rotating blinking lights. Sometimes it stops mid cycle. There is no wrinkle guard on . It never did this before, first time! Can anyone tell me what is wrong with the dryer.
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
I have same issue for kenmore dryer
Anyone found solution to this?
par
Ajouter un commentaire
3 Réponses
Réponse la plus utile
Rotating blinking lights in the display is probably an indication that the Wrinkle Prevent option has been selected. Wrinkle Prevent will continue to tumble the dryer without heat after the cycle has ended to help prevent wrinkles from setting in. When this option is selected by pressing the Wrinkle Prevent button on the control panel, the display will count down the estimated cycle time; when the cycle ends, the display will show lights blinking in a circular (or actually rectangular) motion.
To deactivate, simply press the Wrinkle Prevent button again so the light is not illuminated.
Indice 2
2 commentaires:
The light is not illuminated. i posted the video showing the wrinkle prevent was off. yesterday the dryer did the rotating blinking lights again and stopped before the cycle was over.
par
I have the very same problem, the dryer works only for a few minutes and then shows rotating lights and some time later has 3 blinking lights. Clothes are still wet
par
I found that one pin of the 3 pin power lead (110 VAC) was partially damaged, perhaps not proiding enough current for heating. After the lead was replaced the dryer has been working perfectly.
Jolanta
Indice 0
Yeah, because the dryer has a choice, when Wrinkle Guard is off, when your dryer gets to cool down mode, it now shows 10 minutes left
When Wrinkle Guard is on, when you dry finishes with the drying cycle and wrinkle guard is on your dryer stays on, but if wrinkle guard is off and when your dryer finishes cool down mode, then your dryer stops working.
Indice 0
Ajouter une réponse
JANET DEJESUS sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 1,930
