Aller au contenu principal
The 8th generation (E110) of Toyota's best-selling compact car.
Questions au sujet de 36 Voir tout
How do I install cabin air filter in 2002 corolla?
I bought a cabin filter to install in my corolla. I was able to partly remove the glove box door so it hangs down and out of the way. I cannot see where the filter goes and Im afraid to start unscrewing things beacause the area is quite close to the passenger air bag. Where exactly does it go and do I have to unbolt or unscrew anything to get at it ? I am at my wits end trying to figure this out. Thanks, Joe
Répondu ! Afficher la réponse J'ai le même problème
Indice 3
Ajouter un commentaire
3 Réponses
Solution retenue
Hi Frank, thanks for your response. I read your answer and watched the video but the video did not look like my car. I took my vehicle to a garage yesterday. The mechanic could not figure out where to put the filter so looked it up on his store computer. The Corolla LE, which mine is, does not use a cabin air filter for that year. The other models do, but mine doesnt, so mystery solved. Thanks for your help though. Joe
Indice 2
2 commentaires:
the corolla CE does not have a cabin air filter either
par
I have a 2002 corolla LE and I can't find the filter I don't think It has one?
par
Réponse la plus utile
Joe,
There should only be one screw to remove. The filter box has tabs, not screws.
Have a look at this video and it's done right in front of you.
Good luck,
Frank
Indice 4
2 commentaires:
+ fair video, great titles
par
My 02 corolla doesn't have a screw to remove. Now what?
par
I just checked on my 2002 CE and it does NOT have a removable filter it has a enclosed foam filter. the glove box has 4 screws attached and is not like the video described.
Indice 2
4 commentaires:
Hey guys, Im having the same issue. I have a 2002 Corolla le, and cant find a removable fiter. Its like a black foam type. And looks pretty hard to unscrew..
par
Saludos,
Me pasa igual que a William, tengo un corolla 2001 y no encuentro el filtro, para mi entiendo no lleva un filtro. Muchas gracias.
par
I saw the foam filter but can't drop the glove box.
par
2002 corolla s and I can also see the foam behind the glove box but I can't remove the glove box either. It doesn't have a screw on the side and doesn't just squeeze out either.
par
Ajouter une réponse
josephcook sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 55
Total : 20,874
