Aller au contenu principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 questions Voir tout
Engine not going over 1000 RPM and falls back down
Engine not going over 1500 RPM and falls back down while my leg is still on the pedal and transmission is in park and the car’s not moving. What it might be? Transmission issue? Engine? Thanks in advance!
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
1 commentaire
have you had the codes read?
par
Ajouter un commentaire
2 Réponses
Solution retenue
@tillhimself
does the engine ever go over the 1500RPM even if the transmission is in park or neutral? This does not sound like a transmission issue but either a fuel or sensor issues. I’d check things like bad crank shaft, cam shaft position sensor, MAF as well as a throttle position sensor. It is of course also possible that your car is in limp mode. You need to give us more information as to how long this has been going on and if there was anything that preceeded this. You also should consider having the OBD scanned to see which codes you are getting.
Disconnect the battery and wait for 15-30 min then reconnect. (make sure you have your radio code if your radio requires one)See if that changes anything.
Indice 3
It's happen after replacing new crankshaft position sensor
Indice 0
Ajouter une réponse
Sergio sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 1,907
