Aller au contenu principal
Pour réparer ensemble - Je crée un compte
La manette sans fil Xbox One modèle 1697 est sortie en 2015 et a remplacé la manette modèle 1537 et a corrigé certains des problèmes trouvés sur ces modèles. La manette modèle 1697 comprend une prise casque intégrée de 3,5 mm, qui la rend compatible avec la plupart des casques tiers sans avoir besoin d'un adaptateur. Cette manette a été abandonnée et remplacée par le modèle 1708.
Why is my right trigger always activated even when i'm not pressing it
My right trigger has been like this for a year now i am going to open it up once i get the tools and i am wondering if anyone knows what is wrong and how to fix it.
Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
2 Réponses
Solution retenue
If the right trigger is faulty . When you open it up , you will notice that the trigger makes contact with part of the board ,it may be spring that the trigger makes contact with maybe faulty or maybe need to be cleaned out .if u do open it up try n use 99% alcohol to clean it out of it is messed up . Also the part the trigger makes contact with may be going bad especially if it acting with out you touching it.
Indice 2
1 commentaire:
Would Lysol Disenfectant spray work?
par
What I do is hit the RT or the faulty button really hard with my hand and after a few times, it worked. Not that I necessarily recommended this as the problem does come back occasionally. Do this at your own risk
Indice 2
1 commentaire:
Wtf i just gave it a shot and it actually worked, thank you ive been tryna open it and I don't got the torx screwdriver I was looking around for a bit then I decided to look online and boom seen this and I gave it a wild shot and it actually worked like wtf so many controllers I got rid of I could've just done that😂
par
Ajouter une réponse
Bailey Smith sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 20
30 derniers jours : 76
Total : 23,745
