My F-250 Super Duty with 5.4 gasoline engine started sputtering and sh
It would not restart. I was told by a friend to replace the fuel filter and did so and it still does not start. What could be the problem?
Are there any codes being cast . Do you hear the fuel pump hum ? To check this turn on the key and listen at the side of the truck for a humming sound it should last about 5 seconds or so after turning the key . if you dont hear it you probably have a fuel pump issue and will need to replace it . You may also have an air issue check the air filter if it is plugged bad enough it can cause the same issues . Your best hope for finding the problem is to get the codes read and go from there . Hope this helps
Could be bad ignition coil(s). You should see the “Check Engine” light illuminated on the dash. If it is lit up, Autozone can check the code.
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 208
