Why are my fn keys not working?
Fn keys wont work unless you hold down the fn key button, does anyone know a fix for this? A fix that would make it so that the fn key doesn’t have to be held down
If I’m understanding your question correctly, it sounds like the behavior you describe is correct.
The secondary function of the F-keys should work when pressed at the same time as the Fn key.
For example, if you want to open a Help page in most applications, pressing F1 should work. However, if you wanted to Mute the audio, you would instead press Fn+F1.
I play a game that requires the fn key to be held down, so I can use the f keys to switch between tabs on the game
so would there be a way to make it so that the fn key is always held down?
I looked around and could not find anything. Hopefully someone will provide some information on how to do it...
Hrm. That's an odd one.
Does the game have any key configuration options? You may be able to map the tab switching to the standard F1 - F12 keys.
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 24
Total : 10,168
