Why isn't my Dyson charging?
Dyson Cordless yellow (v6 animal or motorhead? ) upright stick vacuum and handheld)
At first when I put Bumblebee ( I named her after Transformers) on the charger the light came on and the vacuum went vrrm for a second before dying , than after that nothing just a click , now just silence and no light .. reminiscent of old car in the winter when the starter or alternator go out . I d like to know if there is a way to know which the problem is and if it's something I can myself fix and or replace.
6 commentaires
When i plug my dyson on charge it blinks all lights for a second then nothing, no power at all. What is wrong with it
par Lucy Miller
My dyson v7 was working fine in morning then suddenly it stopped working and now it doesn’t charge too I have cleaned it as well but nothing works shows no light
par Ghazal Tahirali
Hi, I have cleaned all parts of my V6 Dyson and still not working. Blue light flashing, then yellow light. What shall I do?
par enei_15
hi,i had a problem with dc35,motor had packed in so ordered a new dc35 motor only to find the battery wouldnt fit,seemingly there is the type a and b.typical.
went back on amazon ordered a new battery that would fit and found that the charger wouldnt work.the light on the charger didnt come on when connected to the battery.was told to buy a new charger.didnt do that.
the charger is plugged directly into the hoover and not through the holding craddle.but even this was not allowing the charger to make good connection to the battery.
removed battery completely and plugged into charger turned on power at the wall,light on charger came on and battery charged
hoover working
par scott dunbar
The problem of my Dyson cutting out was not the battery. I pulled the power head apart, cleaned it of all the hairs etc and most importantly oiled the bearings on both ends of the small motor and the bearing end of the brush. Do not use mineral oil for this. I used Lanolin oil which I think will not attract dust. Voila! No new battery needed. If the power head motor is seized and cannot turn the motor cuts out after a few seconds, and this fixes it.
par Alex
Afficher 1 commentaire en plus
