Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Petit train Thomas le petit train à piles avec circuit.
Not working at all
I have just been given this by my sister. I have had the train on charge for few hours but nothing no led, music, movement, just nothing all the components and connections look OK. How can I find the issue to fix the train. Thanks
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
3 commentaires
Hey, Kelly. Do you have a multimeter?
par
Hi yes I do own one
par
It is working for music but not moving
par
Ajouter un commentaire
1 Réponse
Solution retenue
Here's a teardown of the train. With the charger unplugged, set your multimeter to DC Volts and measure the voltage of the battery at the battery terminals. It should say on the side of the battery what the voltage is supposed to be. If the battery measures the correct amount, measure the voltage again with the black lead on the negative battery terminal and the red lead on the far end of the red wire. I would think it terminates at the back of the switch. If there is no voltage there then the in-line fuse is blown and will need to be replaced.
Petit train Thomas – Schéma du système et composants
Indice 1
Ajouter une réponse
Kelly Kennedy sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 41
Total : 2,526
