Mixing Paddle won't turn
Mixing Paddle does not turn whether in machine or out. Motor and pedestal for paddle work without pan but will not work in pan.
I had a similar problem, you need to perform the steps to replace the shaft seal then clean and lubricate the shaft. It may take a lot of force to remove the shaft. I used a dead blow rubber hammer and a drift to drive mine out. You need to be careful not to damage the shaft or bearing in the bread pan while driving the shaft out. As far as lube I used 3 in one oil but I’ll probably re-lube with silicone plumbers grease.
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 8
Total : 1,163
