Aller au contenu principal
Repair guides and support for LED, LCD, HD and other Vizio TVs.
Questions au sujet de 890 Voir tout
Vizio Tv stuck on startup screen
Vizio tv stuck on logo screen
Répondu ! Afficher la réponse J'ai le même problème
Indice 4
13 commentaires
Will that work if your TV is frozen and cut on or off by the remote,but unplugging it got it to go off.What if when I plug it up,the picture is still frozen and I can't work it with the remote?
par
I fixed my vizio V505-g9 , by first unplug the tv for a few minutes, then plug it in and turn it on, when you see the language where your stuck, push the input button and the +volume button at the same time, it should reset the tv in about 30 seconds.
par
I have the same model of TV with the same issue. I'm stuck on the language selection screen. Despite holding down the + volume and input button, my TV did not restart on it's on.
par
Michael...thank you! I had tried everything and nothing Worked until your suggestion. I held down the input button on the back of the TV with the volume up button and poof....the TV came right one. Thanks!!!!!
par
Michael, thank you! It worked!
par
Voir 8 commentaires en plus
Ajouter un commentaire
5 Réponses
Solution retenue
To reset the tv;
Turn off wall plug , press and hold tv power on button (on the tv not on the remote!) for approx 30 sec.
Leave tv unplugged for 30 minutes and then restart tv by using tv power on button.
Indice 4
4 commentaires:
It didn't work.. any other ideas
par
That didn't work for my TV neither, I really need more help & ideas
par
nope did not work
par
I SWEAR THIS DID WORK FOR ME. (VIZIO FLAT SCREEN MODEL E500i-B1)
1. I unplugged my TV from power source.
2. I held the power button on the TV for 15 or more seconds.
3. I waited at least 30 minutes.
4. I plugged the power source back in and powered on the TV from the back. Once on...
5. The side information and instructions menu came up about vizo TV
6. I then used my remote to scroll down and choose reset TV
7. The box came up and asked "do you want to reset?" (I SELECT YES)
MY VIZIO WAS RESET
par
Pressing the power button when your TV isn’t plugged in will never do anything. (Think about it.) If your Vizio is stuck on the logo the problem is the main board, which you can replace. I had the same problem and fixed it. Before you say "No way I could open up my TV" that's what I thought but after looking at a youtube video on replacing a Vizio main board I realized you just need a screwdriver and to pop out the old board and put in the new one. It’s only $50 for a new main board and what do you have to lose if your TV is otherwise broken? My VIZIO E600I-B3 was stuck on the logo, and I ordered a used "main board" from a parts site online. I removed all the screws from the back. Then I carefully placed my TV face down on a towel on a table and popped the back off. The main board has several connectors. Carefully remove them (take a picture first so you know where the connectors go), unscrew the four screws, replace the board, and put the connectors and screws back, and then the back on. It took me an hour because I was being slow and careful. Cost me $50 for the board and my Vizio is working as good as new!
Indice 3
My vizio TV will not reset
Indice 1
I had this happen. I switched inputs on the back of the TV to my hdmi (firestick) and did the factory reset from that screen. do the reset- hold down the down arrow and power button (from back of tv) for 10-15s and the menu pops up. it let me use my remote after and everything seems to be working.
Indice 0
2 commentaires:
did not work
par
Didn't work with me, either. I feel like I'm stuck with a 55 inch paper weight!
par
JUST bought this TV. Stuck on the “where is your Vizio TV located” screen. Unplugged it…didn’t hold the power button because come on…there's no power. Waited 30 minutes. Tried again. Got to that screen and it's stuck again. Only button on the remote that works is the power button. Appears this “smart” TV isn't even mildly clever.
Indice 0
Ajouter une réponse
drywalldogg sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 34
7 derniers jours : 217
30 derniers jours : 954
Total : 72,432
