Aller au contenu principal
Tutoriels de réparation et d'entretien pour les véhicules produits par Lincoln Motor Company.
Questions au sujet de 36 Voir tout
2000 lincoln town car heat
I have a 2000 licoln town car signature series and about a year or two ago I had the heater core replaced but now at the wrong time off the year the heat don’t come on the display comes on and adjust and does it’s stuff properly but for some reason the heat dosent work, I have check the fuse under the driver side fuse box inside the car at the EACT Blow motor fuse and it fine.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
2 commentaires
Is the fan blowing? Is it no heat at all or there may be heat just not blowing properly?
par
no the fan isn’t blowing and the there is no heat blowing at all and the eact blow motor fuse is fine
par
Ajouter un commentaire
2 Réponses
Solution retenue
I found out it is in the dispay unit a wire that controlled the motor had shorted out but allowed the display to continue to work so I wired a switch to the blower motor and ran it inside the car with it hooked straight to the battery and the blower and put a fusable link in the wire and it works
Indice 1
Have you looked at blower resistor relay board?
with the fan not blowing, it points me more at the relay board or the blower motor.
Here is a youtube video of someone replacing it on a 2002.
https://youtu.be/KxPuEg9EsbI
Indice 0
2 commentaires:
will it work for a 2000
par
From what i could find 98 to 2002 are all very similar.
Before you drop the money i would vheck the blower motor connection as he did. Ensure you are getting 12 volts. Pull fuse ensure it went away so there isnt any odd stuff there. If you maintain the 12volts. I have replaced multiple relay voards on work vans but the lincoln seems to look very different then anything I've seen before and im not sure how you would test it easily.
par
Ajouter une réponse
Dakota Brooks sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 26
Total : 642
