Aller au contenu principal
Commercialisé en mars 2017, le G6 est le smartphone phare de LG fonctionnant sur Android 7.0. L'appareil est compatible avec tous les grands opérateurs de réseau. La réparation risque de compromettre l'étanchéité et de rendre votre appareil vulnérable aux dégâts d'eau.
20 questions Voir tout
Touch screen not working
I have a phone labeled “LG Fortune 2”, I chose “G6” because appearance-wise it was the closest, “Fortune 2” not being in the list of devices.
It got wet though not soaked - rained on , predictably would not boot. The moisture telltales all turned orange.
I dried it out and it booted fine, screen lights normally, but the touch screen will not work at all. The only way to get it to light is the home button.
What, if anything, can be done to correct this?
Thanks.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Thanks. I will replace the digitizer. I see they can be had for about $10.
par
Ajouter un commentaire
2 Réponses
Solution retenue
Sounds like you need a front digitizer replacement. If that isn’t the issue, it could potentially be a logic board short. Water damage is tricky to diagnose directly, but I would try a digitizer replacement first.
Indice 0
As Jonathan said, water damage is tricky to diagnose. There may be corrosion on the screen connector causing the touch not to work. Its also possible a component on the board is shorted out. You will have to replace the whole screen assembly (glass, digitizer, LCD) if you want a new touchscreen because it is bonded together. A new screen will do nothing though if the corrosion isnt cleaned off of the connector, or if the logic board is shorted. Its going to be about the same or cheaper to replace that phone than fix the screen.
Indice 0
Ajouter une réponse
Andrew sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,763
