Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Manufactured in 2004/ 2 gallon tank/Oilless Compressor/ Model number FP204800/ Repair for this compressor is straight forward.
Why does my compressor take so long to get up to maximum pressure?
It takes several minutes, more than 20, to get up to maximum pressure. Also after a couple of cycles the compressor won’t start again.
Répondre à cette question J'ai le même problème
Indice 3
2 commentaires
Is there oil in the compressor?
par
oil less compressor...
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
cladoo  you did not tell us what you have checked and what exact model your compressor is. I know you picked the device but we just have to be sure. Usually, if an air compressor is taking long to the fill it typically is either a seal problem, gasket failure, or an intake or pressure valve failing. Your “after a couple of cycles the compressor won’t start again “ could also be indicative of an electrical air compressor that is laboring to fill. That could be an issue with the motor/capacitor. If you have a bad run capacitor it would then no longer start. Start by checking on those things and let us know what you find.
Indice 1
Ajouter une réponse
cladoo sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 9
30 derniers jours : 26
Total : 6,946
