Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Une cafetière domestique fabriquée par Keurig, sortie en 2011. La réparation de cet appareil est similaire à celle de tous les autres modèles Keurig.
Leaking water into the cup along with the coffee
I use my Keurig B40 with K Cups and plastic refillables. Both have the same problem. Yesterday, I noticed that water was flowing into my coffee cup along with the coffee. This makes for a rather weak cup of coffee . I thought that there was a leak where the top needle punctures the K Cup. I removed the rubber seal aroung the needle. I cleaned the seal and the surface around it. There was a lot of old coffee around the needle.
I reassembled the seal and made a new cup of coffee. The same thing happened. When the brewing was complete, I removed the K Cup. The top was dry. I found the same thing with the plastic reusable. Water is bypassing somewhere, but the top is dry.
What should I do next?
I found the problem after taking the top cover off the Keurig B40. The hose to the water injector had pulled loose and thus most of the water was bypassing the K Cup. I put it back together and the problem is fixed for $0.
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Remove the top cover. There are 2 screws at the front under the cover. Then check the hoses.
Indice 0
This problem happens eventually to 90% of Keurig (and other) machines when brewing reusable K-Cups like My K-Cup. There is an easy fix for this available on ebay for $4.95 that works like a charm. It’s a new part to add in the lid of your brewer in seconds without tools and is guaranteed to fix this problem instantly or your money back - including return postage.
Click this link:
https://www.ebay.com/itm/171557357690
Indice 0
1 commentaire:
This is an old picture from 2015 when the price was $3.69.
par
Ajouter une réponse
Brooks2 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 23
Total : 3,359
