Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Sorti en mai 2014, le Chromebook 2 est doté d'un écran de 11,6", d'un processeur Intel Celeron et d'un SSD de 16 Go. Il est identifiable par son numéro de modèle XE500C12-K01US.
How do I fix broken audio jack?
One day, I go to use my headphones on my Samsung Chromebook 2, but I am greeted with very distorted audio. I tried everything I could to try to fix it. (Wiggle the headphone jack, remove anything in the audio jack port, etc.) After a while I found out the the headphones work perfectly fine when the mic button is pressed on them. I tested another pair of headphones, and the same thing happened. It seems that whenever I use a pair of headphones with three plastic rings on the jack, the sound is very distorted. BUT, when I use headphones with only 2 plastic rings, it works perfectly fine. Any ideas?
(My headphones worked perfectly fine before, so something must have happened to my Chromebook port.)
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Fixed by bending a piece inside the jack.
Indice 0
Ajouter une réponse
Tyler Meece sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 610
