Hyper x Revolver s wiring positions for a jack replacement
I have the Hyper x revolver s headphones with mic, I have the audio working the only issue is the mic. Green is on pole 1 , Red is on pole 2, Blue is on pole 3 .. I have 2 wires left copper and white, they do not go on pole 4, already tried that, anyone got any other ideas ? The manufacturer says it goes green is left channel, red is right channel, blue is ground and white and copper is for the mic, of course they do not tell you the order. This is for Xbox
5 commentaires
Is it possible you could send me a picture of the order of the wires inside the headset as I forgot where they go
par Elliott Smith
i had the same problem. after some messurments i came to this for an AHJ connector.
1 white - mic (+)
2 copper and blue ground (and - mic)
3 red - right speaker
4 green - Left speaker
par Ramon Marees
Hey I have this issues and I read your answers, but was it resolved. After studying this, only 1 of the 2 standards were tried. The 2nd standard with the mic being on pole 2 and the ground being on he sleeve might work. I'm going to try my hand at fix this for a friend and put my soldering to work. If I encounter some roadblocks I'll be back thanks everyone for your suggestions.
par Nolan Howard
Hi guys,
any update on this?
Thanks.
Jaime
par Jaime Blanco
For anyone looking for the HyperX Cloud revolver S pinout to manually replace aux jack, the following worked for me using a third party AHJ 4 pole jack header:
1 -white and copper (left as was did not untwine as suggested with other headsets)
2-blue
3-red
4-green
par Anonymous Helper
