Aller au contenu principal
A series of 40 inch LCD HDTVs by Sony.
schematic square box w/ lightning bolt symbol
Sony model KDL-40SL150 no power, just red light.  the power supply board has a burnt spot where the schematic symbol - square box with lightning bolt in it appears. is this just a fusible link and can I close the link for a fix?
Répondre à cette question J'ai le même problème
Indice 0
1 commentaire
If there are burn marks on a power supply I typically just replace the entire power supply.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
@franko1
We need to see what the board looks like to determine if the board is repairable and what part may have failed and why. post some images of it with your question Ajout d'images à une question existante
Sometimes it could be as simple as just replacing a capacitor whereas other times the whole board may need to be replaced. again, we need to see it to be certain.
Update (11/24/2018)
Looks like a solder bridge and it could be multilayered board. You can try and close it by solder a jumper across. Make sure that your fuse is ok. worst case scenario it does not close the circuit since you may not get to the second layer of the board and can’t close the circuit.
Indice 3
Ajouter une réponse
Frank Jean sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 146
