Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Tutoriels de réparation, démontage et informations de diagnostic pour l'iPad Apple de 4e génération avec réseau de téléphonie mobile CDMA 4G LTE (Verizon), disponible avec 16, 32, 64 ou 128 Go de stockage. Sorti en novembre 2012. Identifié par le numéro de modèle A1460.
iPad 4: Black screen, no charging and not powering on!
I have had an iPad 4 for a while now, I decided to start using it again. I had known that the lightning connector stopped working last time I had stopped using it, and I also remember turning it off at 50%.
When I tried powering it on few days ago, it didn’t turn on or charge. So, I decided to replace the lightning connector thinking it had finally died and the battery had probably drained itself. I used the following iFixit guide: Remplacement du connecteur de charge Lightning de l'iPad 4 CDMA I was actually able to replace the connector fairly easily following the guide (kudos for that!)
But, when I tried to turn the iPad back on, it doesn’t turn on nor charges. I have tried the following things:
  1. Different charging cable.
  2. Different wall connector of the charger (the thing that slides into the iPad charger).
  3. Charging using a computer + iPad’s cables (in case the charger was entirely broken).
None of these result in any response from the iPad, no battery symbol, no apple logo, nothing. Would anyone have any suggestions for me to try to debug this?
Thank you!
Répondre à cette question J'ai le même problème
Indice 0
2 commentaires
How long has it been since you had last put it down and stopped using it for a while?
par
Last I powered it down was a month ago. And I distinctly remember turning it off at 50% -ish battery.
par
Ajouter un commentaire
1 Réponse
Réponse la plus utile
It’s definitely not a battery issue if you had stopped using it for only a month. Sounds like a board level issue going on here, probably a bad tristar IC (U2). I would take your phone to a local and reputable microsolderer and see if they can assist you with soldering a new tristar IC onto your iPad’s logic board.
Indice 1
1 commentaire:
I will try that and report back, thank you!
par
Ajouter une réponse
Muhammad Osama sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 21
Total : 681
