Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Console de jeu de télé produite par Sony Computer Entertainment ; la PlayStation 4 Slim (série CUH-2000) est un modèle de remplacement plus fin pour la PS4 originale. Annoncée le 7 septembre 2016.
Why every time I start a game my ps4 shuts off without warning?
Why every time I start a game my shutouts off without warning. Its not an overheating problem . I checked.I tried switching outlets and using a power supply box and in combination worked but now it does not?
Répondre à cette question J'ai le même problème
Indice 9
1 commentaire
Every time i load in to any of my games it shuts off
par
Ajouter un commentaire
14 Réponses
Réponse la plus utile
Dear Escobar,
I read you facing problem, Its because of processor getting hot suddenly with heavy processing.
It can be fixed by cleaning all air path and cooling fan.
and use extra cooling fan from out side it will help you to keep your ps4 getting heat up fast.
Indice 2
7 commentaires:
What if you cleaned the airways and the fan and it still does the same thing. This all started when I tried playing horizon zero dawn when the data for the application went corrupt and ruined all my data so I wiped the system and reinstalled all my data except for the horizon data . Was fine for about a day then I woke up to my system wouldn't turn on and when it did turn on it said there's an error and got stuck in this infinite loop . Well I rebuilt the database and it was fine again but now I suffer the same problem of when I boot up a game it'll shut down by itself . I can watch Netflix for hours and it's fine but once I try to boot up a game it powers down
par
I've been having that exact problem I'mma buy a new internal harddrive
par
Ps4 pro cuh-7015b
Starwars force works
Skyrim V and infamous Second son: both fail as soon a the online update downloads
If you run them the ps4 pro instant turns off.
All netflix Hulu prime apps work fine
Not on long enough for it to be a heat issue
Turn on with disc in ,launch game,system turns off
par
Had the same issue with original PS4, and found the fan was at fault, i found it beep a few times before switching off, have since replaced the fan and now is fine, also cleaned and re-added thermal paste to help with the heat........just got to fix the blu ray drive now as thats faulty.
par
@hypermechanic I am having the exact same problem , were you able to fit it ? Please help !
par
Voir 2 commentaires en plus
Put your PlayStation in Safe Mode And Update From The internet And it will
Fix Your Problem
Indice 2
4 commentaires:
i was tyrna play fornite and it just shuts off my ps4 and everytime i try to go back in it dose the same thing
par
That's exactly what mine does. I start Fortnite and it shuts down!
par
I have this exact same problem, i’ve tried to start fortnite like 3 times and it goes to pre loading screen and then my game shuts off. ☹️
edit- TYSM! It worked!!
par
Ok nice but WHAT WORKED FOR YOU?? WHICH OPTION WORPT FOR YOU KISS I HAVE SEEN A LOT OF OPTIONS BUT YOU MENTION NONE OF THEM THE THERE ARE STILL PEOPLE WITH THIS PROBLEM SO IT WOULD BE VERY HELPFUL THAT YOU MENTION YOUR SOLUTION
par
I took it completely apart, cleaned all the dust out, and reapplied thermal paste to the APU(after cleaning the old gunk off). It works perfectly now.
https://youtu.be/KD5Ihb4Ou_Y
Indice 2
i had the same problem with my ps4 slim and what i did was simply remove the internal hard drive and first inspect it for any damage inside and out, and when i found none, l looked at its connection part. i saw it was burnt out so i immediately bought an external hard drive to save all my data and went online and bought a new hard drive. then, i simply connected the new drive and reloaded all my data. not only was i able to enter a game (after weeks) i was also seeing my playstation running faster, smoother, and all in all, better!
i’d highly recommend to do this.
Indice 1
Same problem with me I can watch movies I can play dvd games but when I start a game from system storage it’s shutdown I think maybe my hard drive have faults so I change it still same the problem is I find is a cockroach is make spark in power supply and make some parts damage so you need to change your power supply it’s will work fine
Indice 0
If you watch a movie on say Netflix does it stay on?
Indice 0
I had this exact same issue with a ps4 I bought 2nd hand, privately. a month after I got it it started randomly shutting off or putting it into rest mode, for about three months. none of the suggested remedies helped me.
A week ago I had the brainwave to blow out as much dust as I could, so that is what I did, with a small compressor I have. so far no problems at all……..5 days and counting.
Indice 0
Updated my firmware from safe mode and it works fine now
Indice 0
I think you should update to the latest version
Indice 0
It could possibly be over heating, it might be worth pulling it apart and cleaning all the dust out of the heatsink and the fan.
Indice 0
Yeah I had mine saying during games the ps4 was too hot although it was not hot to touch. Cleaned out the inside of dust and put it all back together again then upon starting it starts fine but soon as I start a game (RB6 siege) it gets louder and shuts off about 30 secs after loading the game any solutions or could it just be knackered ?
Indice 0
1 commentaire:
Yea, you need to apply new thermal paste on the processor, it’s heating up too quickly. It’s been a while so you might’ve gotten a new system or managed to fix it already.
par
If anyone sees this, every time you take apart your ps4 for any reason you HAVE to replace the thermal paste or else you’ll cook the processor and then your ps4 will be completely dead. Anyway to answer this question it’s definitely the thermal paste, 99% of the time it’s the main cause of a ps4 doing this because the processor is heating up too quickly
Indice 0
This might not be the answer but it worked for me all I did was change the small battery inside the console and when I put it all back together I put a new battery in it's like a watch battery and then after left the bottom and the top part off and it works does it hasn't shut off yet I've been playing on it for about 2 and 1/2 hours
Indice 0
اطفاء جهاز بلاي ستيشن فجاه بدون اي سبب
Indice 0
Ajouter une réponse
Jordan Escobar sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 16
7 derniers jours : 39
30 derniers jours : 200
Total : 49,794
