Aller au contenu principal
Le Dremel 4000 est un outil multi-usage rotatif à vitesse variable. Il est compatible avec tous les accessoires rotatifs Dremel.
Questions au sujet de 15 Voir tout
Loose Wire Need Connection Point
My husband used my dremel to cut drywall. I’m sorry, ex-husband…. I took the tool apart and cleaned out as much as I felt was safe to do, but there is a wire loose that I can’t find the connection for. It’s a blue wire coming from the small board behind the speed adjustment. There is a brass “U” shaped hook on the end. Where does it hook to?
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
It attaches to the motor as well. The square shaped metal on the tip of the blue wire goes on a slot on one of of the sides of the motor brushes, on the plastic case. You may need to work it around to make it fit the slot. Then put the brush on the top of it.
Source: http://messageboard.dremel.com/Topic8053...
Indice 0
Ajouter une réponse
A Moryer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 136
