travis, besides your printer cartridge, have you made sure that your settings are okay? go to Start then settings then Printer/Faxes
Right click the printer icon, and click printer preferences
Click the color tab and remove the check from Print in Grayscale
Also try this to see if it is the cartridge or the printer
Press Setup . The Setup Menu appears.
Press the Down-arrow button to select the Print Report Menu , press OK. The Self-Test Report option will display.
Press OK to print the self-test report.
Press Cancel to clear the screen.
Let us know if this will make a difference. Good Luck
A voté
Annuler
Indice
2
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
