This is an easy fix!
When you take the ice maker bin out of the freezer, you will see a long, arm-like wire along the bottom of the bin. The end of it fits into a square 1" hole in the back wall of the freezer.
This arm and the mechanism in the hole are what turns off the ice crusher for just cubes to be dispensed. Like a clutch that allows you to change gears.
Set the ice bin aside and go to that square hole on the back wall of the freezer. Inside that hole, there is a horizontal bar, about 1/4" in diameter, positioned about 1/3 of the way down from the top of the opening.
With your finger, push it down. It will click into place. You'll see it's the bottom of a square that's in frame in that opening and where the end of the arm needs to go.
Once you have pushed that little square frame down, it will stay down so you can replace the ice bin and now have cubes.
Just remember that when it's working, that mechanism will bounce up and rest against the arm from the ice bin.
If you remove the ice bin, you'll have to push that down again before replacing the ice bin.
That's it!
A voté
Annuler
Indice
20
Annuler
Faites défiler ce fil pour trouver l'endroit approprié pour y placer ce commentaire. Cliquez ensuite sur « Ajouter commentaire à cette contribution » pour le déplacer.
