Aller au contenu principal
Pour réparer ensemble - Je crée un compte
The fifth-generation Elantra debuted at the 2010 Busan International Motor Show in April 2010. The fifth-generation Elantra (2010-2015) added a two-door coupe variant in addition to the standard four-door sedan model. These Elantra vehicles included six-speed automatic or manual transmissions.
Car seems to be intermittent misfire
Car seems to be misfire however there is no check engine light to confirm this. Car just rolled 200,000km and I have never had a problem with car until now. The misfire happens during mid acceleration and is more noticeable during cold weather. the misfire only last for short period of time before it dissipating. Had plugs replaced which helped for a couple of days but the misfire has returned. Any suggestions?
Répondre à cette question J'ai le même problème
Indice 1
1 commentaire:
You may have to consider the hightention coil, it fints over the spark plug.
par
Ajouter un commentaire
4 Réponses
Had you had a proper car check recently? If not, I’d suggest you do that, because the problem might be not with plugs, but with pistons, valves or head itself. Can also be a coil issue or ECU tune isn’t proper. Can be a lot of things, so giving your car a proper service is a must-do in your situation (especially after 200k km).
Indice 0
3 commentaires:
So my mechanic took my car for a drive in hopes that he could experience the phantom misfire and luckily it happened for him. The bad news however is that he spent a whole day going over everything under the hood and was not able to find anything wrong and because there is no check engine light he is unable to detect a code. A couple things I forgot to mention was that I had the Radiator replaced a bout two months ago and the cam shaft sensor.
Idea?
par
Cam angle might not be adjusted in ECU, which can cause misfires. Try ECU remapping.
par
My friend has golf, and its missfire when it's cold. The reason is oxygen sensor, when the engine hot, exhaust hot, oxygen works probably and car runs ok. May help in future for someone.
par
Probably one of the coil packs for the spark-plug. I’ve had this happen twice. Relatively easy and inexpensive fix. For $80 you can get a four-pack of ignition coils of good coils (just swap them all out on the car while you have to tools out. I swapped only the one that was misfiring and a week later a different original coil started to fail.) Shouldn’t take more than 20 minutes or so (unless you are like me. it SHOULD take 20 minutes . . . end up being triple that time).
Way cheaper this way as well, dealer said they would do it for $450 for 1 coil. An OBII Reader BlueTooth is how I found out what was going on. Another $80, BUT you learn much more about your car and if the mechanic is taking you for a ride
Indice 0
Ignition coil packs. Each sparkplug has its own pack and when one starts to go you'll the miss, but generally no check engine light.
The DYI Fix:
a. ~$65 on Amazon for a set of four ignition packs
b. 10mm socket with a 4" extension
c. Torque wrench
d. About 40 minutes of time
Or the dealership can do it for about $600.
Indice 0
I recently got the same issue after replaced a faulty ECU due to constant misfire on cylinder 4(I did swap new coils and plugs it didn't work, that's why). and it seems the car work fine for 2 week and it has the same problem as original post.
Any idea if the original post problem has been resolved?
Indice 0
Ajouter une réponse
james sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 69
Total : 4,141
