Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Étiquette de la série Dell Inspiron 17 5000 (modèle 2018) Le modèle exact peut être déterminé sur le support Dell en utilisant le numéro de série (Service Tag)
only keyboard replace on dell inspiron 17 5770
can you only replace the dell inspiron 17 5770 keyboard?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
Can you provide the service tag so I can find you the correct part?
par
Ajouter un commentaire
2 Réponses
Solution retenue
Raymond Bernard, yes it can be done. Download the SM for your computer from here It’s not easy but possible.
Indice 2
1 commentaire:
SM only covers palmrest/keyboard replacement. Not keyboard removal//install of palmrest. Welded in?
par
Yes, depending on how you define 'only'. The keyboard and palm rest are pretty much integral, you need to melt plastic tabs to replace 'only' the keyboard. I have replaced my 5770 keyboard. The repair manual is still (11/2024) available here: https://dl.dell.com/topicspdf/inspiron-1...
Essentially you disassemble the computer from the bottom. The manual explains the procedure step-by-step. For me, the hard part was popping the base cover, even starting at the corner as directed; it took more force that I expected. The second time I opened the case to upgrade the network card it went quickly.
Indice 1
Ajouter une réponse
Raymond Bernard sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 5
30 derniers jours : 21
Total : 1,521
