Aller au contenu principal
A game console released in North America by the Nintendo Company in 1985, called the Nintendo Entertainment System, model NES-001.
20 questions Voir tout
Blue screen after powering up NES
I recently found a dusty old NES, controller and some games (score!). The power light was blinking when i hooked it up, so i took it apart and cleaned it (and also disabled the 10NES chip). Put it back together, cleaned the game cartridges and hooked it all up. Now the power light is solid red, but the TV screen is a solid blue/purple color. I connected the NES to my TV via an AV Cable RF Box. Do I need a different kind of connector, or is it something else wrong with a component in the system itself? thanks in advance!
Répondre à cette question J'ai le même problème
Indice 2
1 commentaire
The same thing happens with Nintendo Wii. (caused by an error)
par
Ajouter un commentaire
4 Réponses
Réponse la plus utile
Take a cotton swab and some medical isopropyl alcohol. If you have the option not to dip the cotton swab into the container, don’t do that, but I have still had decent results with doing so after drying a touch. Run the q-tip along the contacts of the game you are having the blue screen error with and you should see the tip turn golden or black because these carts had 30+ years to accumulate dirt. Finish cleaning both sides and dry with anything but your breath or you can just choose to oxidize the cart. It’s your choice, your game.
If option ^1 doesn’t do it for you, I’d go find a long Philips 1 screwdriver and prepare to spend 20min-1hr opening up your console so that you may depress the contacts on your NES. This can be achieved by using a thin yet sturdy fork to pull the contacts in your loader pins out towards you with as little malformation to the pins as possible. You may use the alcohol soaked q-tip method here as well in case your pins received a thorough enough dirt bath from your games.
These methods fixed every problem I’ve had and I’ve gone through all of the color codes. If you have any more questions, I would appreciate if we create a running dialogue for any others reading so that this ends up being the last post on the site about the blue error code. Have a good day and I wish you luck with your almost new plastic box.
Indice 2
buy a new nintendo entertainment system instead or use an nes emulator for nintendo switch. download it if you have nintendo switch online.
Indice 0
1 commentaire:
this is not helpful at all. do you even use your brain before typing the answer?
par
Another solution: Clean up the nintendo entertainment system.
Indice 0
1 commentaire:
thank you for your useless comment. stupid Indonesian.
par
If there is no game in the slot, the blue screen and red light will blink simultaneously. If there is a game, just slightly put the game in so it is not jammed all the way in, but won't push down. by putting it in so it can just barely clear the case when you push it down, this may solve your problem. when it is in, and doesn't work, turn the power off, and just barely push it forward (in the tray's 'down' position) and then turn the NES on. Do this until a clear image pops up on the screen. Let me know if this does/doesn't work. Thanks!
Indice 0
Ajouter une réponse
Njeri Mburu sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 9
7 derniers jours : 41
30 derniers jours : 158
Total : 14,724
