Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le smartphone phare de 2017 de Huawei. Sorti en mars 2017. Il est doté d'un boîtier unibody et d'une double caméra arrière, développée en partenariat avec Leica. Disponible avec des options de stockage de 32/64 Go et six finitions différentes. Numéros de modèle VTR-L09, VTR-L29, VTR-AL00, VTR-TL00.
Huawei P10 Antenna cable broken
So i was replacing the screen on my huawei p10 when i accidentally broke of the antenna connector on the board. i put the phone back together with one side on the antenna unconnected, thinking that the phone would work but i wont be able to make any calls. when i turned the phone one everything seems to be working fine. i am able to make calls and use wifi etc. My question is so i need the antenna, its currently not connected in my phone but everything seems to work fine
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
3 Réponses
the network signal will be very low ( out of service ) cannot make call .
You can jumper the antenna very easy.
Indice 0
1 commentaire:
is their a guide somewhere on the net?
par
I had the same issue. Broken off the connector when replacing the battery.
I've broken the connector from the main board, that's where the camera is located.
Connected the bottom side of the antenna. Strange thing is that everything works perfect. But I dont know if I have a lower signal.
Indice 0
Same thing here. Did you encounter any problem?
Indice 0
Ajouter une réponse
tony sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 21
Total : 1,087
