Aller au contenu principal
Repair guides and support for televisions manufactured by Sony.
Questions au sujet de 648 Voir tout
horizontal lines at bottom of screen
Hi, i have a KD 55S8500D Sony Bravia and i have these horizontal lines that appear at the bottom of the screen, they are very disturbing
Some other info: Tried full reset, restart, changed picture mode, didnt work
The lines seem to follow the colour of the image above it, if this is the picture it may look like this
ABC
_____
The lines only appear when pictures appear
here are some photos
(hope its added i cant see the pictures at mobile)
Update (12/22/2018)
@oldturkey03
these ribbons?
so far i only pushed these 2 ribbons, didnt had any noticable effects
Répondu ! Afficher la réponse J'ai le même problème
Indice 2
Ajouter un commentaire
4 Réponses
Solution retenue
@seafury
horizotal lines like this are most commonly caused by a bad panel (failed gate drivers on the LED driver board). Check to see if you have thin ribbon cables entering the side of your TV (those come from the driver board and enter the LCD screen. Those are bonded to the panel. Apply some pressure on the ribbon cables that corresponds to the area where the line is. If those lines disappear, it is possibly a failed bond. Those are hard to fix permanently without the proper tool but sometimes a tightly applied strip of clothes tape will restore it for awhile.
Indice 2
3 commentaires:
ive pushed some ribbons that i found behind the tv, didnt do much help tho
par
@seafury no. The ribbon cables are on the inside of your TV.
par
Sorry for the late reply, i found those ribbon cables(thanks!) but it did not help much :c its been nearly 2 years and things has gone worst
par
I’m also facing the same issue now
KDL-43W800D horizontal lines in bottom of my tv
@seafury Whats your tv status now did u solved the issue bro?
Indice 0
1 commentaire:
Hey man! thanks for the ping! (i would have forgetten about this without you!)Thing has gotten worst unfortunately
par
This is what it is currently after a year and a half
Indice 0
1 commentaire:
even me i have same issue since a year. its kdlw800b 55 inch. someone told me replace the panel which is very expensive for a 3d tv.
par
Hi my Everest tv had a horizontal lines at the bottom.. what would I do? What do you think is the cause?
Indice 0
Ajouter une réponse
Yusuf ashraf sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 6
7 derniers jours : 22
30 derniers jours : 143
Total : 15,127
