Aller au contenu principal
The Motorola Razr V3, also known as the Motorazr V3, was the first Razr released into the market in the third quarter of 2004.
22 questions Voir tout
Razr v3 Wont charge
I recently flashed my razr v3 and now it doesn't charge it says unable to charge. It still works when its plugged in but when I unplug it it turns off. Not sure if it's the batterys fault or the phone's.
Edit: The battery outputs 1.91v on the 2 outside terminals and the 2 inside ones output 0.02v. the phone outputs 2.10v. It still wont charge
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
1 commentaire
could I directly put 3.7 volts to the 2 inside battery leads or will it explode?
par
Ajouter un commentaire
1 Réponse
Solution retenue
Panayiotis Michalos  this “The battery outputs 1.91v on the 2 outside terminals and the 2 inside ones output 0.02v. the phone outputs 2.10v.” sounds like your battery is discharged below the threshold of taking a new charge. Start off by replacing the battery and then re-evaluate. If nothing else it will give you a known-well starting point should further troubleshooting become necessary.
Indice 2
Ajouter une réponse
Panayiotis Michalos sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 30
Total : 2,540
