Aller au contenu principal
Toyota released the 2002-2006 Camry XV30 series as a larger sedan in September 2001 for the 2002 model year.
Questions au sujet de 17 Voir tout
One tail light does not work
One tail light does not work - replacing bulb did not correct the problem.
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
If the running light works but is dim, have someone hit the brake. If the dim light goes out, you’ve got a bad ground. Check the metallic connection from the bulb through the socket into the body or wiring. Rust right at the socket is pretty common, scrub it shiny, put a light smear of grease to suppress later rust. You can try taking a piece of wire, hold one end to the socket contact and find bare metal with the other. A dim running light will brighten up to normal confirming bad ground.
Indice 0
Ajouter une réponse
Marty Pfefer sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 168
