Aller au contenu principal
The Sony XBR-65X850D is a 65-inch LCD Ultra HD TV with an LED backlight and 2160p resolution. Released in 2016. Model number: XBR-65X850D.
27 questions Voir tout
Will not power on
One day my tv was working the next day it would not turn on. I changed the batteries in the remote control. Nothing. I checked the cables. Ditto. I tried the manual power on/ off. No go. All the other devices plugged into the same power sources were all working. I chose not to purchase the annual service contract because I wanted to believe that this was a decent top of the line product that would last some time before needing servicing.That was a month short of two years ago. It won’t fit in my car and no one will make house calls. Is there anything I can do myself?
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
1 Réponse
Solution retenue
kstanley7411  ok you are between a rock and a hard place. Your series TV usually has a self diagnosis function which would get the RED LED to automatically flash an error code. Since yours does not I would think that this is a general power issue. Since nobody is willing to fix it, you may have to consider taking it into your own hands. You’ll have to disassemble the TV (removing the back of it at minimum and checking the power board. If you got a multimeter etc. You can do some measurements on the boards. Post some good images of your boards with your question so that we can see what you see. Use this guide Ajout d'images à une question existante for that. Important, you also want to let us know what exact chassis your TV is (should be on a label on the back of your TV). The general trouble shooting for the No Power situation looks like this
G is the power board
B is the main board
Indice 4
Ajouter une réponse
kstanley7411 sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 10
7 derniers jours : 51
30 derniers jours : 192
Total : 6,180
