Aller au contenu principal
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
20 questions Voir tout
iMac Late 2009 won't recognize external SSD at boot
Hello,
I’m upgrading my iMac Late 2009 from a 2 TB HDD to a 1TB Crucial MX500 SSD using the kit.
The 1 TB SSD when connected externally is recognized when I’m running High Sierra. When booting, the external SSD is not seen at all during in the Restore mode/Disk Utility screens. The USB 2.0 adapter seems OK and is seen at boot when another 1 TB HDD is connected at boot.
I’m able to install and boot High Sierra from that. Want to do the external check before removing the screen. Is this a known problem with Crucial MX500?
Read online somewhere to try Samsung EVO 850 due to a SATA link negotiation issue.
Would be so nice to save this iMac from the recycle.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
2 Réponses
Solution retenue
Got the Samsung Pro 850 1TB working just fine. Will be returning the Crucial MX-500 in the kit. Ifixit folks, please take note and you may want to modify your kit!
Also, the metal drive adapter needed drilling out two holes with an 1/8 drill. The iMac original shock-mount stubs look like they use a 6-32 screw thread not the 3mm threads in the holes. The 6-32 threads were just the right size to self-tap.
So both the Crucial and Samsung SSDs were compatible with the kit’s USB 2.0 adapter, but the Crucial was not compatible on boot time with my iMac late 2009.
Indice 1
Réponse la plus utile
It sounds like your SATA to USB adapter is not able to support the Crucial SATA III (6.0 Gb/s) SSD.
Indice 2
1 commentaire:
See if this fixes your issue SATA to USB Cable with UASP
par
Ajouter une réponse
JOHN CHEN sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 631
