Aller au contenu principal
A series of 40 inch LCD HDTVs by Sony.
20 questions Voir tout
Sony tv no picture has sound
Immediately after I turned power on to my Sony xbr-75x850e tv Heard a small pop. Sound came on normal but no picture. DTV box light on. TV light on. Does not feel hot. No burnt smell. Less than 1 year old
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
@megh27
disconnect all inputs. disconnect the power cord. Hold the power button depressed for about a minute, then connect one video source. Try something like a game console or a DVD player (just in case the issue comes from your DVR box).Right now it sounds like it could be a backlight issue as well as a video issue, With the TV on and sound working, shine a flashlight at an angle(in a darkened room) against the screen. If you can make out shapes and silhouettes, it is a backlight issue. Could be a bad backlight array or bad power board. If you do not see anything it could be a bad main board or T-con board. If that does not work you may have to replace the back on your TV and check a few things. You will need a meter for that and it will help if you post some good pictures of your circuit boards with your question. Use this guide Ajout d'images à une question existante for that
Indice 1
Ajouter une réponse
Megan Harris sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 11,203
