Aller au contenu principal
iPhone 4 pouces commercialisé depuis mars 2016 avec une configuration de matériel similaire à l'iPhone 6s. Disponible en Argent, Gris sidéral, Or ou Or Rose, avec 16 ou 64 Gb de stockage. Modèles A1662 et A1723.
1049 questions Voir tout
Why is my iPhone SE reboots itself / won't charge?
Hi everyone,
After replacing my Iphone SE IOS 12.1.2 battery, I have the following issue :
  • The phone reboots itself every 5 minutes approx., while using it or not, plugged in or not.
  • The battery is stuck around 13% and won’t load
I’ve tried to :
  • Change the cable and charger, wall charger or USB plugged in my Mac -> same
  • Plug back the old stock battery -> same issue (what?!)
  • Softly brush the charging port to clean it-> same
  • Installed a new battery (so the 3rd one) -> same
  • Hard Reset -> same
  • DFU Restore -> same
Other :
  • The battery state is “Service” in IOS parameters (for the 3 batteries…)
  • Doesn’t seem to have this issue when plugged in my Mac, while in Itunes restore mode (the one with the Itunes logo on the phone screen). NOT 100% SURE.
Do you know what may be the cause(s) of this issue and what may be the solutions ? Maybe we can discard a battery issue as it appears on 3 different batteries.
Répondu ! Afficher la réponse J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Solution retenue
There are some tiny components just above the battery connector. It’s not uncommon for them to get fully or partially dislodged during a DIY repair. One of them (highlighted) is critical for communicating the battery charge state to the CPU.
If it is damaged or missing, it will need to be replaced, which requires a micro-soldering repair.
Indice 6
1 commentaire:
Hi dear, i have the same problem but witn an iphone 11, any help?
par
That’s one very fine answer with an explanation and schema. And guess what : BOOM perfectly nailed it, kudos to you !
As we can see this FL2400 component is missing, probably damaged using the plastic spudger. Now I have to find a micro-soldering repair shop nearby, too bad we are 7000km away ;)
Thanks again ! I really appreciate your help.
Indice 2
4 commentaires:
7000Km? Pfft, that's nothing :>). My record to date is receiving something from 12 000 Km away (Zambia)
par
Nice ! Well maybe you'll receive one day something from France :p
par
J'espère bien, ça me ferait plaisir d'aider mes cousins!
par
Hey there did you ever get it fixed? How much did it end up costing you if you remember?
par
Ajouter une réponse
Julien sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 851
