Aller au contenu principal
Tutoriels de réparation et de support pour le OnePlus 5T, un smartphone Android avec un écran AMOLED de 6,01" sorti en novembre 2017. C'est le successeur du OnePlus 5.
Issues with screen after replacing
Hello,
I'm experiencing some issues after replacing my screen. I'm getting a lot of ghost touches when scrolling, and every few days the screen goes crazy with clicks. Completely unusable. Can't do anything but hard reboot which fixes it. The Keyboard is a bit off. Most gestures work, but only if you use a different one each time. Example: You can't use 'V' twice in a row. You have to do a different gesture each time or it won't respond. Music gestures don't work at all.
Everything else works as it should.
Any idea what could be causing it?
Répondre à cette question J'ai le même problème
Indice 1
Ajouter un commentaire
2 Réponses
Probably needs the digitizer cable reset. Démontage du OnePlus 5T here is the tear down video if you feel like doing it yourself. The LCD able is around 3:43. If that doesn’t do it it is probably an issue with the motherboard connector or the LCD connector itself. My guess would be that it is not seated properly.
Indice 0
Original screen folder Amoled
Indice 0
Ajouter une réponse
Liam Mooney sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 8
Total : 1,772
