Backlight only works during startup
I recently changed the screen on a Xiaomi Mi A2 Lite. When I start the phone up, the Android One logo displays with full brightness and colour without any issues.
The problem is that once the phone turns on there is no backlight. You can still see the display if you are in a dark room and everything seems to show correctly. I have tried updating and factory resetting but still having the same problem.
Any advice would be much appreciated.
Did you ever find an answer to this issue? My phone developed the same problem yesterday.
par Chris Robbins
I have the same problem with a replacement screen. Did you find any solution?
par Jan Buchar
Have you found what was causing this?
I’ve the same issue, replaced the lcd on a xiaomi mi a1 and the backlight is present at the logo startup but completely black after that.
On a dark room I can barely see the screen and all it’s working, but adaptive light button is missing, seems like the bootloader is able to use the backlight but not android itself
par Horror Coder
