Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Le smartphone OnePlus de 5ème génération (OP5) est sorti le 20 juin 2017. Il s'agit du successeur du OnePlus 3T et du prédécesseur du OnePlus 5T.
Screen doesn't work after dropping mug on rigt top corner of screen
My phone still partially works as I can hear notifications coming through, shutter noise when I turn it on, alarm still goes of and tapping noises when I touch the screen were buttons would be however at first there was just coloured blocks on my screen when I turned it on but now there is noting just black. I think there is a problem with connection between screen and motherboard-how do I fix it and how much is it likely to cost?
Répondre à cette question J'ai le même problème
Indice 2
Ajouter un commentaire
1 Réponse
Réponse la plus utile
If you truly believe it’s just a connection issue, try disconnecting your screen and reseating it. If this fails, you more than likely are going to need to replace your screen. The reseating will be free as long as you don’t break anything, but a new screen will probably be just shy of a hundred dollars. Heres the screen replacement (with frame):
OnePlus 5 Screen and Digitizer Assembly Replacement
the part:
OnePlus 5 Screen
Image Replace a front glass digitizer screen assembly compatible with the OnePlus 5 smartphone. Features a 5.5 inch 1920 x 1080 pixel AMOLED Display. Includes the front plastic frame.
Produit
OnePlus 5 Screen
$79.99
Indice 1
Ajouter une réponse
Sophie MacDonald sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 17
Total : 429
