Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Un tournevis 3,6 V alimenté par Black and Decker. La réparation ne nécessite que des outils courants.
How do I remove/replace batteries in BLACK and DECKER
I own a BLACK and DECKER PLUG-IN RE-CHARGEABLE HAND HELD SCREWDRIVER
DP240 TYPE 2.
IT would not charge/ or hold a charge in the end. Found the replacement batteries at BATTERIES PLUS BULBS, the tech said the company would not allow them to un-solder
the batteries , so I purchased the strapped batteries and will install them myself but I need help in safely removing the old batteries and installing them without damaging the circuit board or its components.
WIllie E Brown
Répondre à cette question J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Réponse la plus utile
Hello,
Follow these steps for replacing the Black and Decker.
  1. Firstly, Remove the screws.
  2. Remove the black sticker.
  3. Opening the plastic tool to pry cashing apart.
  4. Remove the plastic slider by picking it up off the screwdriver.
  5. Now, Remove the handle Screw and plastic tools.
  6. Using pliers or your fingers, remove the leads os the battery.
Indice 1
1 commentaire:
Mine has a wire clip that holds the gear head to the motor/battery body. Find the 2 tiny holes below the lock/unlock icons. Insert a tiny wire or awl to push out the clip.
par Partager
Ajouter une réponse
WILLIE E BROWN sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 19
30 derniers jours : 82
Total : 3,746
