Aller au contenu principal
Repair guides for the the LG V30, released in September of 2017.
20 questions Voir tout
What glue to fix corners
I have broken my screen. All 4 corners are smashed. But no cracks run throws visible display. I want to glue corners to prevent falling pieces apart. Maybe some epoxy? Now it is only in surrounding part of screen. So something what helps keep it as long as passible without continuing falling apart. And then i would use a 3d protective screen glass. Which i hope helps screen also not to continuing screen decomposition.
What glue use for the corners?
Is my plan whit a protective glass use as plaster to add display bending duratibility totally nonsense?
I know i eventually will let change display in service shop. But for now i can live with this demage. So a cheaper temporary solution is what i want for now.
Thanks for any advice.
Répondu ! Afficher la réponse J'ai le même problème
Indice 0
Ajouter un commentaire
1 Réponse
Solution retenue
Try B7000 or E6000
https://www.walmart.com/ip/B7000-50ml-Mu...
E6000 Adhesive Glue
Image A clear industrial strength adhesive. Bonds metal, wood, fabric, glass, ceramic, and other surfaces.
Produit
E6000 Adhesive Glue
$2.99
Indice 1
Ajouter une réponse
Filip Raab sera éternellement reconnaissant.
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 141
