What to do for locked card warning(any sd card
what do i do if my camera says card locked ,no matter what card I put in? I have checked the tab on the chip and it is'nt that.
Check that the card is seated properly inside the camera. It could also be possible that the memory card is damaged or defective, so try swapping in a different Secure Digital card. There is a little metal flap inside the card chamber that detects the lock position for the card. See if that is properly engaging. Sometimes you can re-position it with a paper clip etc. Here is a link to it http://camerarepair.blogspot.com/2009/07... Also, of course, check your user manual to make sure that it is not in the settings of your cam ;-) Good Luck
the second tip was very helpful you'r the first one guiding it after searching an hour for this problem thanks
Hello!, I have the EXACT answer for you. I also own the same camera. Watch this for help:
https://www.bing.com/videos/search?q=unl...
I actually figured how to unlock my sd card before i watched the vid!
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 2,160
